tyre size options
alistairolsen
tyre size options
Post by alistairolsen »
I know a lot is dependant on ride height and tyre cross section, but what sizes have people had on 360s running the correct offset and at what ride height?
185/60 14s came as standard, so 195/45 15 should fit, and Id imagine 195/50 would too. Whats the widest the rear arches will take? what about the fronts?
Post by filthyjohn »
had 205 45 15s on at standard GLT ride height. Rubbed a tiny bit on the mud guards but I think it looks better without them anyway.
I used to run on 195/60 14's and now use 195/50/15 both with no rubbing
Post by 340GLT »
215/40/16 on a 7inch rim with 35mm offset are fine all round, with 7.5inch wide rim on the back with the same offset the arches need rolling!!!
195/50/15's on 15"x7" rims with a 30 offset are fine :D
Nikdev
Post by Nikdev »
I had to bend the inner lip on the rear arches when i lowered my car with 8x13 with 195 tires. And Et:04
