HELP - cant shift a bolt on the prop shaft
sps
Post by sps »
Hi
I am taking out my engine and i cant shift the allan key bolt that holds the centre prop in ive tried everything. it is a normal thread right?
Are these still available from Volvo if i just grid it off???
Thanks
Shane
Don't even attempt to undo this with a allen key spanner you must use a socket type one.
make sure you clean out any cack from the head tap the socket in so its in all the way then undo with a ratchet or bar.
Worst case if you have rounded the head you could cut through the bolt then try and remove the remains or replace with a s/h one. There is a chance volvo still sell the clamps
