Wanted: pillar for rear passenger door
I need the rear pillar from a rear passenger side door. Its the bit that seperates the fixed window from the wind up one.
On mine the plastic has lifted and the metal rusted out.
Any help apriciated.
Don't know where any are I'm afraid Dai, but they can be a pig to get out without scratching the plastic if you havn't done it before. Any ideas on how not to ruin the plastic appriciated!
I've even attempted to remove one as yet. Non of the breakers here have any 300's in :(
Post by petefarrell360 »
I can have a look at some point Dai, I think I've got a rear door that I can break up for that bit. I attempted removing one once, and it is a pig, but possible I think. The rivet or screw at the top is easy, it's the bottom fixing which could be troublesome.
Bottom fixing I've seen rusted in, but a big enough philips and it's fine, drill the rivot out the of the top, and she's free. Now, you need to get it out of the door/window without scratching the plastic!
Cheers Pete
J340GLT
Post by J340GLT »
I've removed the pillar on the offside rear door is that the one your after?
It wasn't to bad removing it..
Pm me if you still want it
I've found that getting the trim off that piece without breaking it is pretty much impossible. Good luck!
