Too Long To warm Up
Too Long To warm Up
Warming up the car takes forever, is it something I have to put up with? or can it be fixed. The reason is due to the car drives rough and shakes at low speed when its not warmed up.
Your thermostat is responsible for blocking off coolant flow untill the engine is warmed up, mine jammed open a while back and i replaced it, getting a thermostat was easy enough, but no-one made a gasket IIRC so i had to cut one, easy enough job.
I usually let mine idle for a minute or two and then start driving, temperature needle starts moving up within a minute of that unless it's really cold.
And if i remember correctly Wahler thermostat is same as Volvo thermostat. And it comes with that gasket.
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
