NO heating help!!!
silvia
NO heating help!!!
Post by silvia »
as above i have no heating,i have fixed the electricle side and the fan works now but it ownly blows cold air and a bit of warm air on the pasenger side. however when the engine is under load or gets hotter than normal it pumps steam out on the pasenger side and mists all the windows up. im gessing its somthing to do with th heater matrix??
wher do i find the heater matrix? do i have to remove the dash?
Thanks for the help
Post by bogbasic »
Hello, before removing the heater matrix, I would disconnect the heater hoses under the bonnet and give the heater a flush through with a hose pipe and a reverse flush will help, too. It sounds like a blockage somewhere in the heater which the flush should cure. A drop of Bars Leaks or, much better, K-seal will cure the leak. Cheers, bogbasic.
silvia
Post by silvia »
it has poored ginger water into the pasinger foot well so i wanna get the dash off to have a good look and i have nearly got it off but i need to take the steering wheel off but cant?? i have removed the big nut from the centre of the steering wheel but it still wont come off, eny ideas will be very helpfull thanks
Ronnie
Post by Ronnie »
if you have undone the big nut already just give it a good hard pull - brute force and ignorance FTW
http://www.filterfeeder.eu
silvia
Post by silvia »
ok i have got the heater matrix out and it isnt easy in these cars is it lol i dont think im ever going to remember wher all of it went.
well the new one should be hear tomorro so i will find out then
good luck, hope you don't have any bits left over :P
silvia
Post by silvia »
well i done it and i have heating thanks for all the help. :D
