Tyres
bungle
Tyres
Post by bungle »
Hi, I have the pleasure of driving a volvo 340 at the moment, at the moment it has 155/80/13's on the back and i find they have little grip in the wet, would it be possible to fit 175/70/13's as I would like a bit more grip.
kaos
Post by kaos »
do belive those are what i have on atm, but am struggling to find any more my last one i got was a partworn.
but these damn 13's are way to skinny for me..
bungle
Post by bungle »
try www.etyres.co.uk, free fitting :)
so can i go ahead and order them??
are you sure they would fit, width wise??
thanks
Should be no problem - the 175 wide tyres were fitted to the same rims
SteveP wrote:Should be no problem - the 175 wide tyres were fitted to the same rims
You really sure on that... esp on later cars, 155's had the trademark 300 rims with 5 sets of double cuts, and 175's had plain steels with full size hubs caps
Yep, I know that in 1982 DL's had 155's and GL's had 175's on the same rims. Doubt they'd change the wheels for such a small increase in width on the later models... Surely early Mk3 360's (I'm thinking GL's) had 175's on them double 5 cut rims?
bungle
Post by bungle »
so will they fit??
blackbox
Post by blackbox »
yes they will fit but i have 185/60-14 on mine and grip in wet is still hard to find but its fun to drift in the wet tho
1984 360glt B19 black
I used to run on 185/60 13's with std steel wheel. They did make quite an improvment.
kaos
Post by kaos »
just checked mine mine arnt 175's as i thought must be the skinny 155/70R13, but i have 175s in my stock pile will deffinitly fit as ive had 6j 14"s under those arches with no problems:)
