What does this light indicate?
owyj
Post by owyj »
As topic says. Its an 1986 360 GLE
Tourinki
Post by Tourinki »
It seems to be shift light. Based on the info i've got about it. It is the most useless accessorie in a 300. And apparently it doesn't even work properly.
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
MJ
Post by MJ »
It's a gear shift indicator. It shows when you should change gear to drive economically.
owyj
Post by owyj »
Thanks!
Well...then this light is screwed up! It even lights when I dont give any throttle.
Best regards from Norway!
dalahare
Post by dalahare »
probably reads off vacum, and there's a leak to it so it stays on?
Just a (probably bad) guess.
It's fed by the renix, not sure what it comes on at, think Foggy said his was around 2500.
dalahare
Post by dalahare »
dalahare wrote:Just a (probably bad) guess.
At least i was right about something. :lol:
Post by trabitom99 »
Tourinki wrote:It is the most useless accessorie in a 300.
You're probably right. But anything's better than a blanking plate ;-)
Haha, no worries mate ;) The econ that fits there runs of inlet vacuum...
baz
shift light
Post by baz »
my 340 has that light too it has lit up a few times but at around 5500 rpm it is fed with power from the renix but mine doesnt work as its makers intended either in the manuals section under electrical theres a wiring diagram for it
84 360 GLT mk2 daily driver
84 340 GLE 1.7 mk3 lookingfor new engine sudenly became a major oil burner at 144,000 miles
