idle strange now purring
blackbox
Post by blackbox »
As topic my 360 B19E fuel injected run ok but it idles with a strange miss its not like its just one cylinder tho it runs the dies for a second the keeps running so it idles at 900 rpm then goes down to 300 rpm what could it be any ideas
thanks guys
1984 360glt B19 black
jarlidge
Post by jarlidge »
hi
i had that on my 360 gle and that turned out to be a air leak in o the fuel line, i don't know if that could be the same on your glt.
blackbox
Post by blackbox »
how did you find where it was
jarlidge
Post by jarlidge »
i had to check all my fuel lines and found that 1 was leaking. once i repaired it i never had any trouble.
blackbox
Post by blackbox »
ok so i will look all the way down then thanks
jarlidge
Post by jarlidge »
its a chance it might be that, its worth a try.
blackbox
Post by blackbox »
thanks i took vacuum hose off fuel pressure regulator and fuel came out so put new reg on and fixed
so Thanks again
jarlidge
Post by jarlidge »
hi
glad i could help!
jeff
