adding electric windows
Posted: 10 Jun 2008 10:53 am
by cheshire190e
is this possible or just more hassle than its worth?
would be nice to have it for the summer :)
Posted: 10 Jun 2008 11:31 am
It's an easy job tbh, the hardest part is getting the wires through the door "snake".
Me and SteveP did it to my 1.7 a while ago, I took pictures to make a guide, but never got round to it. I'll still have the pictures somewhere...
Posted: 10 Jun 2008 12:06 pm
3 or 5 door? 3 doors are harder to source the mechanisms.
Posted: 10 Jun 2008 10:56 pm
by cheshire190e
it will be a 3 door
Posted: 11 Jun 2008 09:34 am
Might well do better looking for and aftermarket kit rather than fitting the original mechanisms, as I said they're really pretty hard to find in 3 door form.
Posted: 17 Jun 2008 04:09 pm
by Jos360
Chris_C wrote:It's an easy job tbh, the hardest part is getting the wires through the door "snake".
Could you find the pictures for me? I am adding central locking and electric windows, but i cant find the way to fit the wires in...
Posted: 17 Jun 2008 04:38 pm
I'll have a look! I'm out of internets at home atm though, so may be a while, pester me again if I havn't posted them in a few days.
Fitting the wires is a pain, the loom will be tapped to the snake under the dash, which makes feeding the wires hard. I can't remember how I did it, just that it took longer than fitting the mechs :( I *think* I used a GRP 3mm rod, as I had some lying around ;)
Posted: 18 Jun 2008 12:08 pm
by hatch360
get one of these babies and you will be one sugar daddy
http://cgi.ebay.com.au/UNIVERSAL-M3-CHR ... -INDICATOR_
W0QQitemZ250247532841QQihZ015QQcategoryZ6763QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_
trksidZp1638Q2em118Q2el1247
Posted: 19 Jun 2008 12:40 pm
by Jos360
I eventually fixed it.
If you grab the biggest flat-screwdriver around, and poke it from the inside of the door, against the side of the snake, it will come loose.
Then grab it between the door and the car, and pull it out (not as easy as said), then you can un-tape it and put it back in the door. Then you can feed the wire's with a steel rod.
If you know the trick, it's easy. First door took me 2 hours thinking & working, second door took me 10 minutes :D
Posted: 19 Jun 2008 01:00 pm
Ahhhh... remove snake completely :D If only I'd thought of that, my 2nd door took just as long as the first :oops: :lol:
Posted: 19 Jun 2008 05:14 pm
by Jos360
Chris_C wrote:Ahhhh... remove snake completely :D If only I'd thought of that, my 2nd door took just as long as the first :oops: :lol:
I found it out by accident ;) I wanted to poke a hole in the snake with the screwdriver, but it flipped out. I decided to pull the entire thing out and that worked well.
