Right, I'm nicking Nick_C's internet's to post...
Went under it last night, and it has split from the rear arch to a couple of inches before the 'seam' in the sill. The outer sill looks fine but I think I'm going to cut up the sill, and across. That was I can get to the bit behind easier, and I can see further down the inside of the sill. Also I don't want to be wielding a torch near the front spring hanger for my first ever go at welding.
Looking under there, the other rear one is about to go too.
So, current plan.
I'm not that much of a retard when it comes to making stuff, I've done a fair amount of metalwork in the past. I have a mate with a mid range weldy thing (i.e. the one a couple of models up from the B&Q ones) that he's rebuilt a car with, that he is willing to lend me until I can find a good second hand one. Fake was always supposed to me a spare parts car, then a motorsport car, so it doesn't matter if I don't get it looking awesome first time as long as I get it strong. Kar is going to need some welding, so practise on this is only a good thing. Plus, luckily, I don't need a daily anymore, I cycle to work.
I'm going to cut the outer sill at the seam, after taking out the carpet and rear benches so I don't get sparks on them. Then, see what the game plan is, but I'd imagine I'll build a new jacking point off the car, then make a plate to go onto the floorpan after removing the old stuff, then attach the jacking point to plate, then plate to car, then outersill on.
The rear part of the sill (the bit behind the seam) does that come on a "sill" section or a "rear arch" section? I'm not convinced I'll be buying either, but it might be cheaper than smacking a bit of steel into the right shape tbh.
I had to learn welding sometime I guess... then once side A is done, I'll do the side that is about to go too. The rest of Fake is a good shell, I did chase up a £150 1.7 I got a tip off about this morning, but it had gone, and most likely would have been in a worse state. Right, see you all tomorrow I guess
