ignition starter switch
m_robi1331
Post by m_robi1331 »
Hi guys!
2 weeks ago the ignition starter switch started to play tricks on us.
First the switch jammed, next time we could hardly get the key out and since then it turns very hard and sometimes gets stuck.
We wanted to get it off (the starter switch) to check it out at a specialist.
By the way, are this starter switches repairable?
But things were not so easy because of two screws that do not look like they should.
I will post some pics to check it out:
notice how the upper part where the two bolts are welded look strange to.
This is the drawing from VADIS, and how it should look like.
Please help me guys,I am in a big problem.
Thanks.
84' 360 GLS (B200K) saloon :)
Disgusted
Post by Disgusted »
They are designed to break off during fitting so that they are hard for thieves to remove.
Try molegrips on them (unlikely) but if not you'll just have to cut/drill/grind through them.
1991 Volvo 340 1.7 GL S/R Manual 5-door (69k)
1994 Volvo 850 T-5 GLE Auto 4-door (242k)
m_robi1331
Thanks! Now I understand why they look like that. I think I will cut the two welded bolts off. By the way,do you think that it can be disassambled and repaired? Thx
