Lowering blocks..
Posted: 08 Jul 2008 05:00 pm
by xtrmjks
Since I can't get hold of Classicswede, Does Escort mk1/2 lowering blocks and u-bolts fit Volvo?? also anyone know what is size for ARB bushes, does anyone do a kit?? :roll:
Posted: 08 Jul 2008 11:19 pm
by Ronnie
You can use any block which will physically fit. You don't use U-bolts though. You just use 4 bolts in the standard position, but longer to accommodate the block - have a look and you will see what I mean.
Polybush advertise as supplying for the V300 - although I'm not sure what exactly they offer.
Posted: 09 Jul 2008 01:52 pm
by xtrmjks
aah..I see!! Rang Polybush, nothing for 300's.. :?
Posted: 09 Jul 2008 03:39 pm
by Fuse
Well at least SuperPro has some polybushes available for 300-series.
http://www.superpro.eu.com/Files/Super% ... on%207.pdf
And any rally shop or similiar should be able to make custom ones if you bring them a stock bush as a model. :P
Posted: 19 Jul 2008 07:18 pm
by xtrmjks
Escort MK1-2 blocks are straight fit (got mine from Rally Design),
1.5" blocks £9!!
Posted: 19 Jul 2008 08:18 pm
by Bazboy
Did you have any problems fitting them?? cause i read in post somewhere you need to make a modification somewhere if you lower the back by over an inch? Also how are you going about the front springs?
Cheers Dan
Posted: 19 Jul 2008 09:05 pm
by xtrmjks
No problems, 1 bolt hole , each side, needed filing to clear drive shaft (2 minute job)
I'm using coil overs, so just "wind them down" :lol:
Posted: 19 Jul 2008 11:01 pm
by MJ
I believe it could have been the handbrake cable needs re-routing, although only some models. (eg just 340's or just 360's, I can't remember which)
Posted: 19 Jul 2008 11:06 pm
by xtrmjks
ahh, no hand brake cables on mine I've gone hydraulic.. :lol:
