clio engine conversion
clarke5700
Post by clarke5700 »
hello all im new as you can gess dose any one have a guide in fitting a 16 clio lump into a 1.7 340? any advise would be a big help also i need a prop shaft and bell housing if any one has one??? thanks clarke :D
Post by 340GLT »
Unless you have an automatic your prop will be fine, i do have a spare sump bellhousing and engine mounts that is available. Also for other bits and pieces look here.
http://www.volvo300mania.com/forum-uk/v ... php?t=6092
clarke5700
how much for the bell housing? i need a prop for the reason that the teeth rounded and some one welded the prop to the bell housing :? :?
Bazboy
Post by Bazboy »
Can you weld the prop to the bell housing?? Might be a cheaper solution to my prop problem.
Dan
clarke5700
sorry for the confusion its welded to the out put shaft of the bell housing and yea its been welded did your prop round as well?
Bazboy
Post by Bazboy »
My last prop rounded and took some of the clutch shaft with it and now my current prop is starting to go again as the clutch shaft is pretty knackered so am trying to sort it out properly just thinking welding could be a cheap solution until i can get to where the parts are.
Dan.
