Just time for a Merry Christmas 'look what I've been up to' session.
First off, ghetto jacking technique #4...
Time to purchase axle stands and a trolley jack methinks.
Secondly...XC360?! LET'S OFFROAD!
Anyhoo....down to business....
You lot presumably all know what this thing is all about! You can probably guess what it can tell you from the buttons...Shame 'range' isn't there - all you'd need to know is the size of the tank.
It calculates the MPG from the distance travelled / road speed, and the fuel consumed. The fuel is measured using an amplifier box to buffer the signal from an injector.....or....a flow meter on carb versions. It's an either / or option, and luckily I have the carb version. Weirdly, a spare flow meter appeared on ebay the other week....how rare must they be?!
There's the flow meter....yes, that *is* a broquet device lurking beneath it (hangs head in shame)...
And the speed sensor...which is also fairly ghetto...two magnets on the diff output housing, and a sensor on a bracket.
Finally, here's the device fired up and ready to go!
There's about 5 hours gone into fitting that, mainly because I was going VERY slowly, as its my own car - I've done very little mechanical work on it myself, and I'd rather spare the time to get used to the 'feel' of it, and do it right.
