wanted;
front left hub carrier
as soon as possible
money waiting
would need posted to Aberdeen, Scotland
kev
hub carrier ASAP!!!!!! PLEASE
- petefarrell360
- petefarrell360
Ah, not so sure then sadly, as if it had been just the hub without the spring, strut etc. I have a spare here, as I've already removed the springs and top cups from them.
In that case, as another option, try George Mitchell who is in Dunblane, Friends of the Volvo 300, he can supply replacement spring cups, that can be welded onto the strut by a competent person for about £10 from memory. That way you get to keep your brake disc, bearings etc and know that they are a pair side to side and you know the history of them, hopefully having less problems further down the line!
If you still wanted what I have, I have the strut, with what from memory was a good lower spring cup. You'd need to supply your own top cup and spring I think, (best anyway so they are a matching pair on your car, and suit the model correctly).
Cheers,
Cheers,
Re: hub carrier ASAP!!!!!! PLEASE
hi bit late but i have 1 if your still having trouble
