Hi, do you guys know where the outside thermometer is located on the 360 ?
you'd save me the trouble of looking for it, since I don't have the service manual. By the way, you wouldn't happen to have the service manual in PDF or something would you ?
Thanks...
Thermometer
One of these leaflets should help
http://www.volvo300mania.com/forum-uk/v ... php?t=3825
http://www.volvo300mania.com/forum-uk/v ... php?t=3824
There are lots of leaflets/guides/manuals in the 'Technical Resources & information' sub forum
http://www.volvo300mania.com/forum-uk/v ... m.php?f=24
Welcome to V3M by the way!
- trabitom99
From memory, it's stuck in the RH bumper holder. If it's been retro-fitted, it might just be flapping around in the engine bay somewhere (like mine is )
- filthyjohn
- petefarrell360
As far as I'm aware these temperature sensors will not be in any way affected by wind chill John, not entirely sure how that's measured other than on a calculation of wind speed and the temperature.
Anywho, due to where the sensor is located, it is forward of the engine and when moving, the heat from the engine isn't flowing around the sensor, but when you stop in traffic for example, or turn the car off and let it cool, the sensor is picking up the warm air as it spreads outwards from the engine as it isn't being blown back away from the sensor as it would when the car is moving and reporting a false reading for the outside temperature elsewhere. It's perfectly normal and is an issue on a lot of vehicles, it's something to remember when sitting in traffic or if you stop, then start off again while the engine is still warm, as the reading will be inaccurate for the outside temperature, and might catch you out if you're relying on it to warn you of ice formation.
Unless you had the sensor on a stick, a few feet further forward on your car, there isn't really anywhere where it won't be affected in some way. There are more shielded areas, but cooling fans etc can shift the air around and circulate it around the sensor, brakes will give off heat etc.
