tranmission
kyle_furlong
tranmission
is the volvo 340 driven by propshaft or belts cause i no some of the old volvos are driven but belt
Re: tranmission
It can be either way, if car is variomatic (automatic), then there are belts, but if it is 4 or 5 speed, then there is propshaft, however if engine is 2ltr then there are torquetube and not so traditional propshaft that runs inside of that torque tube.kyle_furlong wrote:is the volvo 340 driven by propshaft or belts cause i no some of the old volvos are driven but belt
So few choices, but pretty easy to know which one it will be, hope this helps
Re: tranmission
Also note that even the variomatic has a propshaft, because the (belt-driven) gearbox is in the back of the car.
Volvo 340DL Variomatic -89
Volvo 360GLT -86
Volvo 360GLT -86
kyle_furlong
Re: tranmission
oh thats ok im about to buy a 1.7 340 just woundered cause them belt at expensive the car need a clutch book time in 2.00 hours so i sholudnt be that bad. on the home page it says the is a haynes manal in the french side but i cant find in anyway could anyone direct me
Re: tranmission
In this forum, there is technical section, there you can find green books which are really great, not same as haynes, but they have more information.
