f7r rwd gearbox?
Posted: 20 Feb 2009 07:09 pm
by nicksonmotorsportltd
any1 know of a rwd gearbox that will bolt to the f7r.
looking to change the rear end of 340 to run mk2 escort style setup atlas lsd axle plus 4-6 link setup.
Re: f7r rwd gearbox?
Posted: 20 Feb 2009 07:11 pm
by 340GLT
There is no bolt on RWD box mate.
Posted: 20 Feb 2009 08:38 pm
could i make adaptor plate of some kind without to many problems.
Posted: 22 Feb 2009 11:00 pm
You could probably use a 240 box and weld together the belhousings.
Have you considered an uprated prop as they are the weak point. The box itself will take a fair bit more than you are looking at putting through.
Posted: 23 Feb 2009 11:42 pm
as long as the gearbox is up 2 a bit of abuse, the prop will be replaced with a decent one.
Posted: 25 Feb 2009 12:03 am
The gearbox is not to bad. Its the props that tend to be the weakest link
