Wipers wont turn off...
Posted: 21 Feb 2009 05:31 pm
by dubstar
This is mildly annoying... ...and yes today I am practising the art of understatement
As soon as I turn the ignition on, the wipers pick up on standard speed, no matter what position the stalk is in. I can make them faster by clicking to that speed, but not any slower or off.
For now I have cut into the Blue wire for standard speed and put a switch in to turn them off. although if you move the stalk to off or intermittent then they're off again at the standard speed. (So they're currently usable, but not great)
They weren't like this when I parked it up. It's just developed over the weeks that it has sat while I've been away.
Any Ideas?
Re: Wipers wont turn off...
Posted: 21 Feb 2009 05:35 pm
by volvosneverdie
Dude, youre not having much luck.
You havnt run over a black cat and then drove under a ladder and through 30 mirrors recently have you?
Posted: 21 Feb 2009 10:05 pm
by kaos
you sure youve put it in the correct of slot and let it settle at its rate normaly if its halfway through a cycle it wil finish it before it stops
Posted: 22 Feb 2009 03:37 am
by dubstar
Yes, I have given it 'the benefit of the doubt' a couple of times it just keep on going.
A bit like that bloody energiser bunny.
As I say, I can't even get intermittent, if you select intermittent it just keeps wiping normally. The only change is if you select fast wipe.
So I now have a toggle switch... (It may become apparent, that I'm quite a fan of metal toggle switches
Posted: 24 Feb 2009 10:16 pm
by sven360
dubstar wrote:This is mildly annoying... ...and yes today I am practising the art of understatement
Any Ideas?
Probably teaching me Granny to suck eggs-but the stalk will activate a switch somewhere along the line which must be US.
Locate and replace would be my advice.
Posted: 05 Mar 2009 05:11 pm
by pistonpen paultje
Probably a worn wipermotor. Had that too once with the GLS. A Cam should operate a switch. But when its worn, it doesn't touch it.
