f7r conversion. (throttle cable)
cindral
Post by cindral »
Hi guys just put an f7r into my 340. What have people been using as throttle cables when converting to the f7r and f7p?
Cheers Ross
Re: f7r conversion. (throttle cable)
Post by filthyjohn »
I used one from a 16v cavalier, but I have carbs so it's a bit different. Try http://www.carbuildersolutions.co.uk for universal kits.
A 240 K jet rhd cable should do teh job
WooDooUK
Post by WooDooUK »
I just used a universal Throttle cable from e-bay. Excellent quality, 6mm Fixed Barrel on one end and a solderless nipple on the other, Combine that with the fork of the volvo cable and job done.
If you TB is next to the bulkhead then you need less than 1m.
kaos
Post by kaos »
yeh, woodoos right
uni cable works wonders, im running one on mine. and mines bulkhead side. easy job once you figure it out :)
-x-salmon-x-
Post by -x-salmon-x- »
im just using an universal one of ebay too works a treat.
