6 speed gearbox
6 speed gearbox
I've found somewhere that offers a 6 speed gearbox that would fit very nice into a 300. It comes with LSD and a good range off gear ratios. The bummer is the price.
Does anyone want to donate £3500 so I can try one???
Re: 6 speed gearbox
This interests me... good ratios and a slipper
It's not per chance off a standard car laying round in a scrappy (say... erm, that well known 6 speed transax mondeo thats common as muck) that you've forgotten to mention is it
Re: 6 speed gearbox
How much
Can't they just do say a normal 5 speeder with LSD for say £50
Re: 6 speed gearbox
Hewland Engineering does similiar boxes, some very nice transaxle setups.
http://www.hewland.com/
Re: 6 speed gearbox
I found these, only rated to low Torque...No good for turbo then!
You can get sequential box for that money as well! No good for turbo, again!!
Re: 6 speed gearbox
could we all put in and have it for a month each, untill one of the 16vs breaks it lol
i'd be happy with a 5 speed straight cut box even 4 speed! with an LSD
Re: 6 speed gearbox
Lol to a 16V breaking the boxkaos wrote:could we all put in and have it for a month each, untill one of the 16vs breaks it lol
Tubby's on the other hand
Re: 6 speed gearbox
That would put a new meaning to a group buykaos wrote:could we all put in and have it for a month each, untill one of the 16vs breaks it lol
Re: 6 speed gearbox
I could go type9 tranx and atlas out back if need be
Write it in your heart.
The code of the West.
Re: 6 speed gearbox
M90+240 axle!! Swedish gone grazy for these now..check 300POWERkaos wrote:lol its gotta fit a 340..
pics?
Re: 6 speed gearbox
What is an M90 out of?
How much work is involved in fitting a 240 to a 340? What set up are they?
- filthyjohn
Re: 6 speed gearbox
340's already have 240 gearboxes, just mounted differently. An M90 is a later box from 940s and 960s IIRC, very tough and mounts directly to the engine. So to fit an M90 to a 300 you'd have to weld in a transmission tunnel for more space and fit either a different diff at the back (like a sierra one), or do what xtrmjks has done and bash in a 240 rear axle on escort 4-link kit. Though I reckon it could be possible to fit a 240 axle to the leaf springs.
Re: 6 speed gearbox
I've always thought about that. How, for example, would you be able to fit a type-9 to a f7p? I know for that you'd have to get a bigger gearbox tunnel, is it possible? I've always fancied a volvo running on escort bits.
- filthyjohn
Re: 6 speed gearbox
When J fitted his, the escort tunnel didn't really take up much more room. it's not that much work if you can weld well. To fit a type 9 would be just the same but you'd need an adaptor plate. If it's for an F7P/R, there's not much point as the type 9 isn't any stronger than our own M47R AFAIK.
