boring out a 2L 360
volvosaurus
boring out a 2L 360
Hello lately i have been think about the possibility of boring out a 2L to a 2.1L just wondering if it is possible? also what is the maximum shave you can do to a 405 head?
Re: boring out a 2L 360
What engine you have? B200 or B19? Both are possible to bore out, but it is easier and cheaper to change straight to b23/b230.
Whit b19 you can use b21 pistons.
B200 there ain't anything pistons from volvo engines avaible. I have heard that 92mm aftermarket pistons for beetle(air engined) are used, but those need some kind bushing to fit to volvos rod.
I thought that the B19 and B200 has the same wrist pin sizes??? The only change I was aware of was the smaller rods.
I should have a set of B21 pistons about or you could go all the way to 2.3
b19-23: 24mm
b2x0: 23mm
Easiest way to get bigger is buying b230f engine or just bottom end. Some parts need to take from old engine to make everything work, but rest is plug 'n' play.
b2x0: 23mm
volvosaurus
i just to trying to keep my car some what legal. My stupid government wont let me drive turbo or supercharged cars or modify engines
just figure the police arnt smart enough to no what there looking at.
ill give the 2.3 240 ones ago cheers for that.
What diffs are people running?i have been think how hard it would be to get a 318i back there or mably a 740 diff
- 340GLT
Just put a 2.3 engine in the car and put the B200E cam cover on it....
B200 and B230 block look exact same outside, but both have only b200 or b230 mark on side of block. Remove that b230 text from block and paint it and no one can say which one that is without removing cylinder head. And only volvo enthusiast will realise that.
But if you want bore out, use those air cooled vw's 92mm mahles. Even them aint bolt on, them are cheap. Compression height need to be 39,6mm. Little work needed, but any motor works shop should be able to do those.
volvosaurus
cheers mate
i think ill run the 2.3 because that is what i was going to do normally but i was illegal but if there that much of a look alike ill just run with it, i got have a 240 engine for free so i just mean i'll do the work to a 2.3L
