I noticed this morning that the fairly large black pipe that enters the centre of the pre-heat flange on my carburettor was perished.
I pulled the perished pipe off and took it into my local motor factors to get a size match, the new one was much longer and I didn't have a stanley knife on me to cut it to size and replace it there and then.
I basically drove home with no pipe at all, about a five minute drive, my car will run but now keeps cutting out at traffic lights etc!
I hope I haven't done irreparable damge, maybe I've trapped air in the fuel system by doing this?
Any ideas?
Justin
My Car Keeps Cutting Out?
1988 340 1.4 DL
- volvodspec
Re: My Car Keeps Cutting Out?
do you still have the old hose?
there's a blocking plug in the hose, creating a hole of 1mm in diameter, if the hole is way bigger than that, it makes the mixture settings wrong causing these symptons.
Thankfully I still have the old hose, does it matter where I position the blocking plug within the new hose?
1988 340 1.4 DL
- volvodspec
Christ thats much better, thank god for this brilliant forum, I positioned the blocking plug with the bigger hole facing the pipe that comes out of the pre-heat flange with the very small hole facing away from it, Im assuming this is correct?
J
J
1988 340 1.4 DL
Doesn't matter either way mate
