Leaded or unleaded?
S10NPH
Leaded or unleaded?
Post by S10NPH »
I have just bought a 1980 Volvo 345. Does anyone know whether it is fine just to put unleaded in it, or do I need some sort of additive?
Many thanks!
Sion
Re: Leaded or unleaded?
No, unleaded is fine.
depends on the renix doesnt it?
pinking alert, danger, pinking alert.
VND, you may have to change your percentage dude, correct answer.
I really can't remember for anything whether or not the valve seats are hardened, but in any case, the advance is far enough you could well get pinking. Super at minimum, lead additive I think you can do without but I'd double check that.
Chris_C wrote:VND, you may have to change your percentage dude, correct answer.
21%
:D
Super to be safe.. but my '82 343 ran fine on normal unleaded without pinking at all, but not sure if that had any alterations done for it to run on it (doubt it!).
A 1980 car wont even have Renix though... points & condenser!
Plus, we need to see pics :D
SteveP wrote:Super to be safe.. but my '82 343 ran fine on normal unleaded without pinking at all, but not sure if that had any alterations done for it to run on it (doubt it!).
Dude!
I was up to 21%!
19%
Bah, well I've never had a problem running pre-unleaded cars on unleaded.
On the subject of fuel, has anyone here noticed any difference running the 340/360 on high octane performance wise?
Post by volvodspec »
what engine do you have?
B14.0E till B14.2S have the soft material in the cylinder head so they need at least RON 96, 98 unleaded will work fine, 95 with lead additive wil work fine but don't fill them up with unleaded 95.
b14.3 and up will do fine on unleaded 95
S10NPH
Post by S10NPH »
volvodspec wrote:what engine do you have?
How do I find this out? :oops:
S10NPH
Post by S10NPH »
SteveP wrote: Plus, we need to see pics :D
I will take some photos this weekend and put them up. I have a small fleet of Volvos for the moment!
Get them all in dude. :D
All volvos qualify for pic status.
You quite sure buddy? Renix's were retarded half way through B14.4E's here from memory, which would be 86/87 ish.
Chris_C wrote: You quite sure buddy? Renix's were retarded half way through B14.4E's here from memory, which would be 86/87 ish.
ha ha ha.
Retarded.
it's not about the renix allthough all b14.4's have renix and some of the late b14.3 models were equipped with renix.
b14.2 is the last cylinder head wich has the softer valve seats, b14.3 and on has an "uprated" cylinder head with reinforced valve seats to cope with ron 95 or even ron 91. b14.2s or lower don't have that so they need leaded fuel
