Crank Pulley Problem
peterpoulos1
Post by peterpoulos1 »
Hi All
Can someone help me with my Crank Pulley?
It has come apart... the rubber binder layer has
hardened & broke both rings apart. Can I weld it
together the 2 pcs of the pulley together without
long term negative affects?
I cant see anything wrong with that....
Love my little GLT!!!
Kind regards
Peter
kaos
Re: Crank Pulley Problem
Post by kaos »
which engine? if it a 1.7 i have one.
It's a GLT, so surely 2.0 ;)
SteveP wrote:It's a GLT, so surely 2.0 ;)
Yes, I too am under the impression that all glts are 2.0. :lol:
Yeah, it'll be a B200 of some sort, only the Volvo engines have that vibration damper/crank pulley held together with compressed rubber. AFAIK the Renault units don't have that, just a simple crank pulley....I think....
I would see if you can get one from a scrappy tbh, the rubber cushion is important to cushion the torsional vibration from the engine, so welding it wouldn't be a great idea. If you completely struggle I have a feeling a new one will be available from the dealer although it won't be cheap.
peterpoulos1
hi pettaw
ok..... thanks for the advice i will try and get a used one.
yes it is a B200 black cover engine... I understand about the
vibration issues.
I havent seen this rubber cushion design on other car's crank pulleys
Cheers Guys..... :)
