F7P engine mounts
Posted: 22 Jul 2009 02:13 pm
by tommysb
I'm trying to fit up the engine mounts for the f7p engine swap, and am a bit perplexed by one in particular. The front mount, where the alternator is, doesn't seem to go on, as the alternator mounting is a lot bigger on the f7p engine. I suspect that this problem could be overcome with a cunning use of an angle grinder, but I'm sure there must be an easier way!
Can anyone who's done the conversion advise as to how they've got this engine mount on, or whether I'm just being thick?
Re: F7P engine mounts
Posted: 22 Jul 2009 07:34 pm
by kaos
you have used the volvo alternator mounts yes? not the renault one which is like a big slab and a half circle of ally?
Posted: 23 Jul 2009 08:41 am
by tommysb
I'm planning to, having unbolted it all, it looks as though there's another mount behind the alternator mount, which 2 pulleys are attached to. Should it just be a cast of using the Volvo alternator mounts?
Posted: 23 Jul 2009 01:45 pm
by tommysb
Hehe, worked it out.
They 'pulleys' were for the power steering, and so not needed. They've now been removed. :D
Posted: 31 Jul 2009 06:11 pm
by linkay
I used the renault one just with a big bit chopped off with the grinder, seems to be okay, i just wonder if the power steering pump will seize after time as it is not connected?? Suppose ill find out :D
