16V engine(s)
16V engine(s)
Post by filthyjohn »
Hello folks,
I've decided to go redblock with my 340 so my renault engines are up for sale. I can DELIVER TO RETRO RIDES if necessary. :D
First up, F7R hybrid 2.0:
This is the engine I bought from Ben earlier in the year, only to find some compatibility issues. It's a late 714 bottom end from a megane, and would need the front quarter of the megane sump (sump supplied) welding to the rear 3/4 of the volvo 1.7 sump. This is to accomodate the chain driven oil pump. As seen here:
See the indent for the chainwheel (top left of the sump)?
Any engineering shop should be able to sort that out for you, personally I couldn't be bothered at the time so pinched the Kent cams that were in this engine for my 1.8. So it currently has standard ones in, not a great difference as they were only RN1601s, the mildest cam they do. Will be supplied with a gunnerchip ECU and standard clio loom. The manifolds have been removed but I can put them back on for transporting. I'm happy to wait in for a courier, as long as it's before Friday 14th as I'm going to RRG09.
Price is a very reasonable £195 ono, with very cheap delivery available next weekend.
Next up is my F7P:
Currently in the car and running sweetly (apart from an air leak around the carbs, but that's not the engine's fault). It's a standard F7P from an R19, running Kent 1601 'sports injection' cams, piper vernier pulleys, Dell'Orto DHLA40 carbs on a homemade inlet manifold, and a williams tubular exhaust manifold.
It's a very smooth lump, no rattles when cold, always warmed up and treated with respect since I blew my last one by over-revving. :oops: It never goes above 6500rpm as I have a nasty propshaft vibration around there. It could rev safely to 8k were it not for that. Even so, it'll comfortably pull 120mph@6krpm, with 0-60 a little under 7 seconds. The engine is still in the car but if somebody wants it I'll pull it out within a day or so.
Pricing is tricky, the conversion parts are staying with me, and the carbs are worth £200 all day if sold seperately so I'm keen to keep those (and maybe put them on my GLT). Given that it has cams and pulleys it must be worth £175 without exhaust or carbs, but with standard inlet and loom. Having said that, an offer around £450 would persuade me to part with the;
engine (£175),
carbs (£200),
1.7 conversion parts (hen's teeth),
williams exhaust with modded downpipe (£80+ work modding it),
Facet fuel pump (£40),
Filter King pressure regulator (£80),
And all wires/hoses needed to fit it.
It all adds up to quite a lot more than I'm asking. If you're interested, let me know what your needs are and I'll happily come to a deal on any combination of the above engines and/or parts. I won't bite or be rude, promise.
Oh and I can deliver anywhere between Sunderland and Somerset on the weekend of the 15th+16th of August, very cheaply.
turnbullj
Re: 16V engine(s)
Post by turnbullj »
so how much for me to bring mine down + you chuck that F7P in for me???? :D
thanks james
88 Volvo 340 DL
55 Fezza Zetec S
Re: 16V engine(s)
Go on Son!
Supa border powaz!
Re: 16V engine(s)
turnbullj wrote:so how much for me to bring mine down + you chuck that F7P in for me???? :D
thanks james
I'm sure we can arrange something. :wink: I'll PM you.
chunkybond
Re: 16V engine(s)
Post by chunkybond »
how hard would it be to put one of those in a 1.4 340?
Re: 16V engine(s)
chunkybond wrote:how hard would it be to put one of those in a 1.4 340?
Less than a day's work if you have all the 1.7 mounts, hoses and wires ready to go in.
Re: 16V engine(s)
Bump, open to offers in order to get rid of these at retro rides.
kaos
Re: 16V engine(s)
Post by kaos »
im tempted top put in a silly cheap offer, and bring my van to RR/jeffs...
Re: 16V engine(s)
^^^Joking arnt you?
Best be quick then.
If you want it loaded for leaving tomorow morning.
it being 2036 in the evening now.
Re: 16V engine(s)
Post by 340GLT »
Buying more engines before getting yours running Kaos????
kaos
Re: 16V engine(s)
Post by kaos »
340GLT wrote:Buying more engines before getting yours running Kaos????
Bit yes no. as i have an F3R in the shed also. Im in the cover my arse stage after the oil pump failing on mine. got my replacement ready, just busy doing my engine bay, and i fancy the cams...
Re: 16V engine(s)
Post by 340GLT »
Those cams are extremely mild tho mate.
Re: 16V engine(s)
Oi stop ruining a sale Ad! :lol:
Yeah they're plenty mild, but either way I have no room in the car now, as there's a bumper, door cards, carpet, bucket seats and a clio exhaust in the back. Engines are still for sale, but will need courier action probably.
Re: 16V engine(s)
Post by 340GLT »
Lol sorry dude i would of bit your arm off for the cams but i already have verniers and i want some lairy cams which come in at £420!!! lol
Re: 16V engine(s)
I feel like buying a 340 to dump that engine in :lol:
