rubber side strip removal
Posted: 11 Sep 2009 10:26 pm
by Tom bailey
I have decided to take the rubber side strips off my 340 and I have removed the actual top rubber but there is a adhesive layer under that is there a chemical which will remove this but will not remove the paint work?
Re: rubber side strip removal
Posted: 11 Sep 2009 10:58 pm
by Speedy88
Softest stuff I know is a bottle of stuff called "sticky stuff remover". Smells a bit like cake if it was made from chemicals. Chemical cake if you like. It's good but expect to be there a while but for that it won't damage your paint. I also find those ice scrapers for windows are good for getting the initial black adhesive off.
Posted: 12 Sep 2009 05:51 pm
by Tom bailey
k cheers. someone just told me that i should try a deoderant spay on sum cloth and then tcut it. wont the spay take the paint off?
Posted: 13 Sep 2009 01:33 am
by Speedy88
solvents should be fine but deo has loads of crap in it which could have some paint dissolving properties. I'm not sure what they put in those things.
Posted: 26 Sep 2009 11:21 pm
by Ronnie
Best thing to use is your thumb - rub until clean, expect large blisters - seriously
Posted: 27 Sep 2009 05:39 pm
by kaos
heat gun!
Posted: 04 Oct 2009 09:48 pm
by Tom bailey
Sticky stuff remover is Brilliant took me over 2 hours to remove the adhesive of the rear panel and then with with sticy stuff remover it took me less than 2 hours to do the rest of the car. i'd recomend it.
Posted: 04 Oct 2009 10:05 pm
by volvosneverdie
Tom bailey wrote:Sticky stuff remover is Brilliant took me over 2 hours to remove the adhesive of the rear panel and then with with sticy stuff remover it took me less than 2 hours to do the rest of the car. i'd recomend it.
man speaks true.
Badge removal winner too.
as i found out after ruining the paint on the back of the GL trying other methods. :oops:
