Front anti roll bar 23/25mm (sway bars)
Well after a lot of searching I will now be able to do anti roll bars. (sway bars)
Now that whiteline no longer offer a 360 bar it has made me work a bit harder on this project.
To get things kicked off into production I am going to need some customers for them.
Based on 10 kit (bar, body bushes and links) we are looking at a aprox cost of £150 - £160 I will need to confirm this price but it won't be far off.
I will be able to do them in either 23 or 25mm can mix and match to make the ten. If less than 10 the price is going to be a bit higher. A number of ppl have been asking me so it should not take long to fill the ten spaces.
If there is enough interest in these then I will also be getting a rear arb made.
Re: Front anti roll bar 23/25mm (sway bars)
Good work, will these be 340 or 360 arbs? Or are they the same, I can't remember?
How will the rear arbs work... similar to the 363CS setup?
Also that's a good price - 360 arb link arms from Volvo cost about £56 for a pair when they were available!
They will fit all 360's and 340's. I will be making them as per the early style and provide the uprated links with them. That way they can be fitted to 360's that used the ball joint links.
As to the rear end when I get around to doing it I'll either make then like the IPD conversion for amazons and 140's or possible have them clamped to the springs. That is something for me to think about once we have the fronts done.
This is good. What I'm after right now is just the rubber end which attaches somewhere around the back of the engine. Will you be doing this as a full kit only or will you sell some things separately?
Speedy88 wrote:This is good. What I'm after right now is just the rubber end which attaches somewhere around the back of the engine. Will you be doing this as a full kit only or will you sell some things separately?
PM me a pic - parts will be available seperatly
Will do in future, not got time right now to get under the car with starting my final year at uni. I'll let you know.
I'll start a new thread in the offer section for a Group buy.
racing-street
Post by racing-street »
them are going to be adjustable?? that would be a great thing to improve the handling of the car I think
