http://www.simpsonsalvage.com/item.php? ... lue=143793
Based in York.. worthy of a few handy spares I imagine, electric mirrors for starters! It looks like its been written off for a broken bumper bracket and number plate panel damage?! Very nice otherwise
Black Volvo 360GLT - Breaking (Not mine!)
i think the frame will be bent- if whatever hit it went thru the towbar it might well be fooked
- petefarrell360
I thought the same at first Hugh, but as Steve says, may have been a higher category. I don't think that car should be there, it looks so clean, tidy, low mileage, well looked after, I think a new bumper, or it could be possible to straighten the metal frame underneath, providing the plastic is not cracked, and you'd have a nice car. That's as long as it hasn't been robbed of bits yet. BTW High spec '89 model too, with the electric mirrors.
nagh - a is complete loss (nothing salvagable)
b is frame/chassis should be crushed, parts ok
c is damage reparable
and d is thefted i think
no. a frame can be damaged, but the car still in class c. class b is just when the frame is damaged so much that it should not be repaired. ie a rollover, or a very high speed stack.
- foggyjames
I think that rear end damage is probably a lot worse than it looks - remove the bumper and I bet that thing is a mess. The number plate panel wouldn't end up at that angle easily.
