anyone know easy it is to put an aftermarket recliner in a 340?
can you use the standard subframes?
fitting an aftermarket seat
Re: fitting an aftermarket seat
Depending how handy you are with a welder
no pictures unfortunatley but when i fitted mine i made a sqaure frame for the new seats to mount to then mounted that to the original volvo seat rails/runners.
easy
easy
monka wrote:anyone know easy it is to put an aftermarket recliner in a 340?
i fitted ford rs recaros to mine and just squashed to volvo seat rail with my hands to make it narrower and bored new holes so it would bolt sraight on to the new seat then welded tabs with the right size of holes on to the side so that it would bolt straight into the standard holes in the floor sounds complicated but is actully really simple can post pics if you like?
kev
kev
85 360 GLT drift beast
clutch kicks ahoy!!!!
