A month or so ago problems stared with the instrument lights which were inverted. They were on when meant to be off and off when meant to be on. For example the blue main beam light was on when on dipped headlights but not full beam, and the indicator arrows were on constantly. This can sometimes be fixed with a sharp tap to the plastic screen.
A little bit more recently the illumination of speedo and rev dials stopped so you can't see the speed at night. The rev needle also drops considerable when side or headlights switched on. It still rises and falls, but stays bellow 1000 rpm or so.
These problems sometimes disappear, but come back. The problem usually exists in damp weather.
I noticed a while ago that the rear window heater didn't seem to be working, or at least not at full power.
Not long ago a strange noise came from the doors while the car was moving and since then the central locking doesn't work.
A friend said it sounded like an earthing problem as the battery seems a bit week if the car isn't started for several days.
Last week I took the car to the local Volvo dealer who said they fixed the problems, but low and behold they hadn't fixed the central locking so 5 minutes later I went back. Apparently all the motors in all doors have blown for some reason. They said there was corrosion on a fuse box which they fixed with spray stuff which was causing the instrument light issues, but they are still faulty.
Could the problems be linked, or independent? Any solutions?
I'm guessing a shorting wire behind the dash is causing the light problem as a tap fixes this. Probably in connection with the light switch.
Thanks for any help you can give.
