Electronics have all gone to pot
The lectrics in my car are a shambles:
* The left hand indicator flashes really fast and the back one doesn't work at all. I've tried changing the bulb to no avail.
* The right hand side repeater doesn't work, again even after having changed the bulb.
* The brake fluid light keeps coming on even though the brake fluid is way above the minimum line.
* When I brake, the night lights at the back come on, but when I turn the headlights on the brake light comes on!
WTF is going on? Help!!
F983 OHD '88 340DL - Gone but not forgotten
C299 LGF '86 340DL - Variomatic jerkiness
- foggyjames
Psychic predictions...
Rear panel ground points shot to hell....remove wires, clean connection to chassis, replace.
Loose wires to brake fluid sensor and repeater.
Still want a drivers side red front wing Tom?
If possible mate, pleasefoggyjames wrote: Still want a drivers side red front wing Tom?
It might be two months before I need it yet as the local panel beater is very very busy. If you could find someplace to store it I'd appreciate it and give you a generous tip
- RandomHero
Whenever one of the indicator lights make bad contact to the wiring and it does not burn the other 2 go very fast, i had that problem once. Check and clean the the connection of the taillight unit or the light that doesn't work. That will probably sort it out. Im nog known with the rest od the problems, srry dude.
Good luck!
Good luck!
- 360 GLT, 1989, Gray Metallic, 115.500 km, PAS, Electric Sunroof, Windows and Mirrors
The car has now been rid of all the electrical problems!
I took it to the garage where I got it MOT'd (they're family friends and I trust him). About 6 hours and just £20 later the car was finished. He even sorted out my carb for me, so now it runs as sweet as a nut.
I'd recommend anyone living in West Yorkshire to check out Cleckheaton Road Car sales, near Odsal Top!
- foggyjames
New blade Tom?
