What sump?
Posted: 14 Jan 2010 10:08 pm
by cam340
im putting a renauld 19 1.9 turbo diesel engine in ma 340 and wonderd if a would need the 1.7 sump and would it fit ?
Re: What sump?
Posted: 16 Jan 2010 11:28 pm
I know the derv head looks like the 1.7 head. I'm fairly sure that the sump should fit but have never tried so cannot confirm. If the 1.7 sump will not fit then you will have to make brackets to support the engine.
Re: What sump?
Posted: 18 Jan 2010 06:44 pm
by Joe
Tractor fuel lad :) Joe
Re: What sump?
Posted: 19 Jan 2010 10:10 pm
by volvodspec
parts catalogue tells lubricant system (oil pump + sump etc) are the same for D16 and B172 models, so big question is will the d16/b172 sump fit underneath the 1.9 diesel engine; if that is from the same engine family the answer probably is yes but if that doesn't fit you'll have to customize the 1.7/d16 sump to get clearence for the steering rack.
Re: What sump?
Posted: 20 Jan 2010 01:09 am
by 340GLT
Will fit so long as its not a later engine with chain driven oil pump.
But the F8Q bottom end i had here it fitted fine.
Cheers Adam
