Im in need of some tips + pointers...
Edcase 300
Post by Edcase 300 »
Hi guys silly question ( i know) but.. im strongly thinking about removing the coachlines/stripes from my 360. Basically some of the stripes have come off due to me bieng a bit clumsy with my neighbours pressure washer :lol: (ive heard if i do remove them i might end up with a brighter line of paint under where the vinyls where-but frankly baby i dont give a damn)....
Can i use a heat gun to remove the stripes? Whats the best way of removing them?
Second Question.. Whats the best way of cleaning the engine bay? Mine is greasy,grotty,slighlty rotty and leafy! :| Any products you recommend? Can i just use detergant+ water?
Just needing some advice really so any is welcome.
One Day... Volvo 360 Turbo ;-)
Re: Im in need of some tips + pointers...
For the stripes... yep heatgun (hair dryer might do tbh) and picking at it to peel it off... might be brittle by this age though as the stripe on my old car took an age to remove, pinstripes probably not as bad at all though. You'll probably find that the paint might be a bit deeper under the stripes but not a huge amount, especially if your car is a metallic colour.
Edcase 300
sweet cheers man sm4 -i just needed to clear that one up :) Have you cleaned your engine bay before? Im just wondering whats the best way to go about that as ive never done it and mine is so filthy :| Is detergant + water a bad idea?
Edcase 300 wrote:sweet cheers man sm4 -i just needed to clear that one up :) Have you cleaned your engine bay before? Im just wondering whats the best way to go about that as ive never done it and mine is so filthy :| Is detergant + water a bad idea?
Ive pressure washed a couple of engine bays dude. always worked well.
Just give it time to "dry" afterwards. Had to wipe moisture out of the dizzy once, but I HAD given that one about a ten min dousing from 678 difeerent angles.
Edcase 300
Sweet.Thanks dude foor the tip-Im going to do that! :P I now have two reasons to show the Vulva some much needed love 340pw
You can get really strong degreasers. An easy one to get is in B&Q citrus degreaser, 'Disolvit Max Strength Degreaser', works quite well for me.
You still need to work it in to thick oil crude, you can try repeated squirting with a spray bottle set on needle jet leave to soak in , repeat etc. Then jet wash it off.
I also have Marine Clean from Frosts, its a bit nastier and requires more rinsing. With effort it can remove cavity wax, but I ended up using white spirit in the end.
I tried Metal Clean or something from B&Q, which has a mild deruster in aswell, but I didn't find it did anything really.
Best to wear glove with any of this stuff, if will de-oil your skin too, but it does grow back provided you don't have any sensitivities :)
Edcase 300
I think i'll have a look in B & Q next time im there :) Cheers dude I will look out for the citrus stuff-for some reason it didnt occur to me :oops: lolz
Hopefully my car will be running again at some point soon as ive managed to convince my (reluctant car unloving) dad to give me a hand in removing the fuel pump.... hopefully its just that...really miss the sound of the old girl and her abilities to (with skillfull driving ofcourse) embarass/ piss on modern cars :lol:
