Cutting out 2.0i
wheelbarrow
Cutting out 2.0i
Post by wheelbarrow »
Hi there. My friends 360 2.0i Keeps cutting out when you go over bumpy ground. It has recenly had new plugs leads dizzy and rotary arm. Just wondered if anyone else has had smilar problems and what there solutions were. Any help would be appreciated thanks
pyro
Re: Cutting out 2.0i
Post by pyro »
Heyhey
I would check the ecu mounting, plugs, wires etc. and make sure its earthed properly with no corrosion on earth leads around the ecu cage.
failing that dont drive over bumpy ground :mrgreen:
Ben
* Disclaimer
Mors Principium Est
Aux fuse box, behind battery. The fuel pump fuse in there corrodes and could be loose
Chris_C wrote:Aux fuse box, behind battery. The fuel pump fuse in there corrodes and could be loose
+1 and/or the fuel pump relay
wheelbarrow
Thank you il do a bit of investagation and see what I find
