L14MNP
Post
by L14MNP » 01 Oct 2011 08:03 pm
You need this fella
See the bearing? professional tools are a must.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
wiganer31
Post
by wiganer31 » 02 Oct 2011 03:36 pm
yea think i see it, is it actually sat in the fly, is that snpon? i cant afford snapon lol, jokes aside though, did it do the job ok?
Post
by foggyjames » 02 Oct 2011 09:48 pm
If all else fails, brand new from Volvo is only about £10. I terminally bust my old one trying to remove it after wrecking it by not putting the torque tube in straight. Love the special tool
wiganer31
Post
by wiganer31 » 03 Oct 2011 03:04 pm
haha alf that's brilliant,
for the price i will just order a new one from volvo,
i'm guessing the bearing is sat in the engine?
wiganer31
Post
by wiganer31 » 03 Oct 2011 03:32 pm
i know im being abit dumb here but could someone tell me exactly what im ordering when i go into volvo for the bearing because they always want every last bit of info, do i need the bearing out of a 360 engine or a 940 engine? partnumbers or anything would be helpfull
Post
by foggyjames » 03 Oct 2011 03:47 pm
Pilot bearing for a 940 with an M46 transmission...or order against your 360's number plate. It's exactly the same part.
wiganer31
Post
by wiganer31 » 03 Oct 2011 08:08 pm
ahh rite so i just need to go in and order a 360 pilot bearing useing my 360 reg?
Post
by Ride_on » 04 Oct 2011 12:14 am
They will get very huffy about you wanting 360 bits say computer says no, then need chassis numbers and so on then have to get out microfiche machine, the 940 might be on the computer.
Post
by foggyjames » 04 Oct 2011 12:49 am
They should be fine with it, as it uses the 940 part number. It was probably a 240 part first! VADIS lists 300s, and I think VIDA does too, so they should be able to find it.
wiganer31
Post
by wiganer31 » 04 Oct 2011 10:39 am
so 360 0r 940 it dosent matter?
Post
by foggyjames » 04 Oct 2011 01:00 pm
Correct - they're the same part. The only exception is that a 940 with an M90 (i.e. your donor) has a different part, which isn't a bearing at all. You may need to remove this from the engine in the car.
As far as I'm aware, any B200 or B230 with an M45, M46 or M47 transmission (including a 360) will have the right bearing. The one I ordered a couple of years ago was roughly £10 (try FRF in Swansea, quoting VOC forum membership, if your local dealer seems expensive) and I remember at the time that VADIS reported an identical part number for the 360 as for a 940 with an M46/47 box.
wiganer31
Post
by wiganer31 » 06 Oct 2011 12:49 am
got the bearing this morning, fitted it, fitted the lump back in the car, plumed it all back in, started and drove it thanks to the help of a mate, the alternator isnt charging for some reason (any ideas?) and the battery is to small imo, runs okish when on the jump leads but when you take the leads off it starts spluttering and kinda missing etc but im 99%sure its down to not haveing enough power to the fule pump and probs other things, will do a propa update tomorrow
L14MNP
Post
by L14MNP » 06 Oct 2011 12:52 am
I am here at the right time - maybe.
My alt was the same, I hadn't connected the voltage regulator (spade wire). You got that sorted?
You got the rev counter working btw?
STREETO WITHDRAWL
wiganer31
Post
by wiganer31 » 06 Oct 2011 01:32 am
you know im dumb by now so any pics of that?
lol,
i will be honest with you i havent put the clocks in yet because i have no idea how the rev counter will work lol, o and the bit that holds the spedo cable to the clocks has vanished so think i need a new cable, the people in volvo know me by the first name lol, any farther witf yours?
