Post
by SteveP » 15 Jan 2008 04:32 pm
340GLT wrote:If my 140mph speedo is accurate then my car does 85 in 3rd on the limiter and 112in 4th on limiter
A GLT will do that stock...
Although 500rpm less with the taller diff
germ
Post
by germ » 15 Jan 2008 10:34 pm
My 1.7 will do it around 9-11 secs to 60 and pulls quick in 3rd.. i think it will do 100mph in 3rd? what i do know is that by 80 it slows accel alot!
will
Volvo 340
1988
Post
by jtbo » 16 Jan 2008 02:09 am
germ wrote:My 1.7 will do it around 9-11 secs to 60 and pulls quick in 3rd.. i think it will do 100mph in 3rd? what i do know is that by 80 it slows accel alot!
will
Hmm, 360GL with 3.36 diff will do 93kph with 2nd and bit above 150 with 3rd, I don't think 100mph is possible with any combination unless revving far beyond safe range?
Anyway 3rd is ridiculously tall gear in these boxes, old M46 was so much better, I have one in my daily driver
Too bad those boxes never made to 300
Citroen ZX Dturbo -97 -daily-
Post
by SteveP » 16 Jan 2008 10:18 am
jtbo wrote:Anyway 3rd is ridiculously tall gear in these boxes, old M46 was so much better, I have one in my daily driver
+1... My 360 feels quicker from 65-80, than it does from 50-70 in third!
Pappa
Post
by Pappa » 16 Jan 2008 05:05 pm
I agree, but as a side effect you hardly use fuel when going 60, 70 (in third) and 80 (in fourth) km/h
dalahare
Post
by dalahare » 16 Jan 2008 05:43 pm
My 360glt took pretty much bang on 13 seconds to 100kph tonight, could have shaved a few tenths off by flat changing, but the old girl gets abused enough.
That's a true 100 kph too, reads 112 on my speedo.
MJ
Post
by MJ » 16 Jan 2008 09:07 pm
Never head of flat changing before, but it seems to involve keeping the throttle wide open during a quick gear change. Doesn't sound too great for the car
I just read one site where someone mentioned not using the clutch while changing gear. I've done that a few times, but you have to exactly match the revs or you get horrid grinding noises
Very occasionally I'll slip to neutral without the clutch when down changing to avoid the first part of double clutching, but you have to ease off the throttle a bit.
hatch360
Post
by hatch360 » 17 Jan 2008 02:22 am
dalahare wrote:My 360glt took pretty much bang on 13 seconds to 100kph tonight, could have shaved a few tenths off by flat changing, but the old girl gets abused enough.
Thats te same time i got but that was when it was not mechanically sound the time should be better than 13. How did you measure it?
dalahare
Post
by dalahare » 17 Jan 2008 11:45 am
Stopwatch from the standing start till the speedo swept past 110kph. did it a few times, and it was normally in the high twelves. it did have a full tank of fuel, a few few spares in the car and my fat arse weighing it down.
Pappa
Post
by Pappa » 17 Jan 2008 06:47 pm
Well I changed the breather hoses and the time is now down to about 18 seconds 0-100kph. Still too much though, and it's not really 100 kph, just what's indicated on the speedo.
Post
by pettaw » 17 Jan 2008 08:58 pm
If you've got bent steering or suspension then its not going to run straight so you won't get a true time anyway. I would suggest a full mechanical going over, first and then you can try 0-100 times
