Interior bits?
sammysideways
Interior bits?
Post by sammysideways »
Im about to start stripping the interior of my 360, anyone want anything?
Re: Interior bits?
Not sure where you are, but would love a drivers side GLT rear door card if someone doesn't take the whole lot :D
theo2468
Re: Interior bits?
Post by theo2468 »
Rear seats please
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
sammysideways
Re: Interior bits?
im in oxford but based in portsmouth so could bring it down next week?
rear seats i think would need collection or courier due to size
shamil
Re: Interior bits?
Post by shamil »
Hi
Do you have a econ Gauge and a center console panel?
:340:
Re: Interior bits?
sammysideways wrote:im in oxford but based in portsmouth so could bring it down next week?
That sounds awesome, I'm in Scotland on Tue and Wed I think,but here Mon and Fri? Beer, Volvo parts or pennies preferred?
Re: Interior bits?
Chris_C wrote: I'm in Scotland
What? Don't get a nosebleed.
sammysideways
Re: Interior bits?
do you have any go faster volvo parts?
Re: Interior bits?
I doubt I have much for a GLT here... pretty certain I have a correct renix unit if you find your's isn't but apart from that I've got rid of any redblock go faster bits....
Think I have an 2.0 LH ecu here from when I was going to swap LH onto my old GLT, requires a loom from a 200/900 and the big ballache which is a flywheel swap. However, you can't really do anything on the stock ECU, it's openloop and has no learning possibility if you ever want to change the cam or carbs, plus it'll be a hell of a lot more economical to boot.
Re: Interior bits?
Y'know this difference between LH and LE-Jet expecting different trigger patterns on the flywheel (the major job) - is it not possible to build something that translates the LE-Jet flywheel trigger pattern into the pattern that LH expects? Thus negating the flywheel swap at all?!
Re: Interior bits?
Easiest way for not wanting to pull the engine is just to mount a 60-2 (for LH2.4) trigger wheel on the crank pulley. Cheap as chips, just not the sexy solution
http://www.034motorsport.com/034efi-eng ... p-105.html
sammysideways
Re: Interior bits?
ermm ok can you give me more details on this ecu?
i thought it would be ok to just change cam and carbs on my 360 and it would be ok, is this not correct?
Re: Interior bits?
It's from a 940 from memory, but same as 240 version. LE jet (that your 360 has) has no "chip" to speak of, all the timing is done via very old skool analogue electronics that cannot deal if anything is changed on the engine. LH is more sophisticated, has a lambda sensor so it can self learn to an extent and can be either chipped or mapped if you get really keen.
A chap on here tried a cam swap once with a decent measuring rig we built for him and noted a small loss of power when he did a cam change, which in my eyes is enough to show the stock management can't deal with change ;)
Both LE and LH only control fuel, so you can either keep the Renix you have currently or change to something programmable there too.
sammysideways
Re: Interior bits?
anyone else want any bits? ill be chucking it out if no which is a waste. dont want much for the bits as its better than chucking them away.
Re: Interior bits?
As there are no pictures... the interior is *not* a standard GLT interior, the door cards at least are the split grey/beige ones which are rare enough if you had to find one for a resto
