Breaking Volvo 360
Breaking Volvo 360
All parts available
Torque tube - £50
Gearbox/ Diff (welded diff) - £100
Bellhousing - £50
GLT interior - £50
GLT alloys - £50
Redline Seats - £60
Torque tube - £50
Bellhousing - £50
GLT interior - £50
GLT alloys - £50
Redline Seats - £60
- trabitom99
Re: Breaking Volvo 360
Any sunroof cables?
will have a look mate.
Dont think its working though
This is going to sound a bit weird, but I'm after the threaded bar/nut that holds the heater box to the bulkhead (it's in the open hole), I dropped mine on removal and can't find it!
Hi Steve.
I have loads of nuts and bolts that i have removed over the years.
If someone could put up a photo of the one you need i could
at least have a look.
how are the front radius arm mounts rust wise (deep or surface)? I could use the radius/tie bars and bottom lever arms too. Willing to post to NI?
Ride_on - when you say lever arms, do you mean wishbones? Because that might be what I'm after...
SteveP wrote:This is going to sound a bit weird, but I'm after the threaded bar/nut that holds the heater box to the bulkhead (it's in the open hole), I dropped mine on removal and can't find it!
should have one of those mate
yep not a prob pm meRide_on wrote:how are the front radius arm mounts rust wise (deep or surface)? I could use the radius/tie bars and bottom lever arms too. Willing to post to NI?
Have you got front bumper? Might be able to pick it up depending on location
Can you take out the front subframe? Not bothered about the wishbones, just need the center bit.
- Attachments
- IMG_2018_zpsd2eced3f.jpg (63.83 KiB) Viewed 48275 times
Drift-rat-jim
Rear axle and drums how much dude
undecided as to which one to keep atm mate as Ive got a rear disc conversion and a normal set up
Dannyboy856
Hi,
Do you still have the 3 piece plastic spoiler from the bottom of the front valance?
Thanks,
Dan
Thanks,
Dan
volvomania
I am looking for the two rubber hose sections that form the filler hose, preferably with your chassisnumber as they've changed over the years.
I believe that top and bottom can differ.
This so that BBB is getting good samples to reproduce.
Can you tell me postage to Belgium or to Suffolk?
THX
THX
