volvo pt 233246, diff to body bush/mounting
CBA
Post by CBA » 01 Aug 2013 03:45 pm
the l-drivings toll.
need one of these.. Maybe two. Asap, poly or rubber.
Re: volvo pt 233246, diff to body bush/mounting
Post by macplaxton » 01 Aug 2013 05:41 pm
What's it for Chris? (340? 360?)
In the meantime take a quick swatch at http://www.volvo300mania.com/forum-uk/v ... =2&t=15203 and http://www.volvo300mania.com/forum-uk/v ... =9&t=13770
Got nothing here as "mac" was working on this one some time ago.
ETA: that number doesn't come up with much. Must be an old thing moulded into the rubber.
CBA
Post by CBA » 01 Aug 2013 07:55 pm
no longer urgent. I used a roll of 'adhesive tape'.
Duralon...
Sounds reassuring.
in a sentence: I giddily taped up the bush.
It's for a 340 1.4, Mac.
The thing looks easily fabricatable.
I am surprised poly ones arent available.
-bogbasic, this was contributing to the rattle of the prop, may have been misaligned for a while, there always was a whine from the axle area.... I will video it now, it be running most excellently btw. Tappets done, carb adjusted re the second throttle not being completely closed = 600rpm idle and very good on fuel. Fast sometimes too. No zebedee effect, apart from first 20 seconds if a bit cold. I reckon its sorted.
Post by bogbasic » 01 Aug 2013 08:32 pm
Wicked work. Them is 'ard to get but I think its on classicswede's to-do list and I sent him an old 360 one a while back to use as a template, so there's hope on that front too.
driftking89
Post by driftking89 » 02 Aug 2013 12:55 am
if you look on my rear diff/mount solved post you will see i can get these almost identical to the original took abit of tinkering but they work better than the orignals
Volvo 340 2.0 Supercharged drift wagon
Volvo 850R 2.3 Turbo
Toyota Celica 2.0 Import
CBA
Post by CBA » 03 Aug 2013 01:46 am
the teheh-hehe ahem!, sellotaped up bush is great - quiet, gearstick doesnt move around etc
Try it yourself! (neil buchanan)
300 miles and holding strong.
Sellotape. Thin, cheap sellotape. Wound with tension, a lot, carefully. And pvc tape.
Exactly Like a crossply tyre without the kite string.
Next problem.
Prop is rattly as a rattle, but its silent and smooth if i hold the gears so as to engage a synchro... Ach.. Adds to the charm. Presumably Prop bearings are unobtanium?... Can fit Oversized bb's? Maybe extra prop holding things?
I should do something about the backfiring on the way down too, you can tell its doing it on purpose just to show off. I think the actual running mixture is a bit too rich = worn main jet?
Post by bogbasic » 03 Aug 2013 11:35 pm
Wicked work with the sellotape - I hope it lasts well. The prop shaft used to rattle quite a lot in neutral with my foot off the clutch. If it was too embarassing for any reason, I used to put my foot on the clutch or rev up very slightly to stop it ;-0
It only ever backfired on me when I had a wonky idle solenoid but that was replaced last year so probbers its the mixture or sumthin ;-?
CBA
Post by CBA » 04 Aug 2013 11:14 pm
it is rich. I dont want to lose the backfiring though :(
500 miles!
Ha ha ha!
I know a bloke who'll weld it up... When it fails i'll do it properly.
I suppose 22 years after ceasing production if I cant find it then it doesn't exist or buying one would be more expensive than making one.....
