omex not working
Mcglone7
omex not working
Post by Mcglone7 »
Bought a clubman rev limit and looked at posts to how to wire up. Got power and stuff but it doesn't seem to limit.
Don't no what it could be :/ suggestions?
Nimminz
Re: omex not working
Post by Nimminz »
You have definately got it wired the right way yeah? (black to earth, red coil+, blue coil-) And is it set up correctly? i.e. 4cylinder and the correct RPM?
Have you got it on soft/hard cut? I found my glt tends to rev past the soft cut but hard works fine.
Mcglone7
Post by Mcglone7 »
Well it didn't say which was which on the contact coils. So i put left positive and right negative. Yeah i set it to 2000-3000 with the hard cut on and nothing.
Nimminz
Post by Nimminz »
i take it it's a renix coil then, When you unbolt the coil have a look at the contacts, there should be a tiny + and - Stamped into the resin round the contacts, can't remember which is which off the top of my head
edit:
taken from volvodspec's post on this thread: http://www.volvo300mania.com/forum-uk/v ... hilit=omex
Hope that helps
Mcglone7
Post by Mcglone7 »
Cheer mate. I'll have another try tomorrow. Spent a number of hours on it already ha.
