Yeeeepp!!
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
01 Volvo S40 Phase 2 Turbo
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
bogbasic wrote:Yo, direct is best and that'll save two hundred miles if you consider it would have to go all the way back to Brum if it came down to me first...
1984 Volvo 360 GLE Saloon
1987 Volvo 340 1.7GL
Additionally -
1966 Ford MK1 Cortina
1971 Hillman Imp
1984 Renault 18 GTD
Additionally -
1971 Hillman Imp
1984 Renault 18 GTD
Good morning people..things are going it's way for now..meter surround checked, indicator cover checked, agent checked..only payment yet to be made..I haven't checked with stevep..on the indicator price..or it has no price tag on it..
Best wishes
Zack
Best wishes
Zack
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Hello derskine, i've PM you the address, please note I did not include the place name it's Birmingham Best Inn..put that right after the room number.
Mucho Gracias..
Zack
Mucho Gracias..
Zack
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
This is the piston that the foundry did. Scrapped of the rust on the edge of the caliper, and it fits perfectly..
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Hello chaps..
A little update..modified brake hose. Made from flame resistant material..hose is suitable for all types of oil and fuel..but the caliper side nut is slightly longer..i think it won't do no harm. Now..all left is to asseble it back..
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Group purchase allowed..
zack360
- Attachments
- Brake nipple hose.jpg (150.85 KiB) Viewed 15811 times
- MockIt_27082015145650.jpg (92.65 KiB) Viewed 15811 times
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Hello all, quick question, can I replace left hand side brake calliper with right hand side? The only difference is the brake hose hole..it will face backward.
Thanks
Thanks
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
No you can not. Try bleeding one when the bleednipple is on the bottom.zack360 wrote:Hello all, quick question, can I replace left hand side brake calliper with right hand side? The only difference is the brake hose hole..it will face backward.
Thanks
The flexi pipe will need to be longer as it will point out towards the ground at the bottom of the caliper. You could bleed it the right way up then assemble it on the car. The pipe would have to be done up first to get it positioned right, then the caliper removed, then bled making sure the pistons don't come out.
I don't know if heat percolation in the fluid is important, but that would be affected.
Overall not worth the hassel or risk.
The bleed nipple is so darn hard to get..i sent the l/h side brake calliper to foundry and ask them to remove the broken bleed nipple..he did remove it and make a new thread..he make it bigger. Actually I already acquired another brake calliper but it's for the r/h side. I'll just keep it for future use.
Thanks for the info man.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Flexi hose fitted..
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Wicked work, man - I have lots of issues with nipples, too ;-0 ;-0 ;-0 ;-0
Next project is to clean the fuel tank. This is what a dirty tank will do to your carb.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Hello experts of 360,
Now the carburettor is clean. I am going to remove the fuel tank. From Haynes manual, 1. I must jacked up the rear of the car.-done-.2. Remove the heat shield from beneath the fuel tank.- I don't have the heat shield, it's carburatoer. 3. Disconnect the gearchange rod at the gearbox and unbolt gearchange from the middle of the torque tube. How do I do this?
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
