Mr.Borrie's 360 Cup V2
mrborrie
Re: Mr.Borrie's 360 Cup V2
Post by mrborrie »
The season of 2014 was not successful. The new build car had some major issues when it first went on the track. The last few months where used to make some improvements on the car that would hopefully resolve the issues of the car stop running after about 2 fast laps on the track.
After a long winter working March 14 was the first tryout of 2015. We went early and brought allot of spare parts. We were guessing to do a series of laps and then go in the pits to resolve more issues that we might encounter.
However the car turned out to be working great, so we spend the whole day racing and having just a great time without fellow racers. It would have been perfect if not the last ten minutes late in the afternoon the fuel pump decided to die on us. Still we are very much pleased with the result of our little 360 now working as we want it. Looking so much forward for the start of a new season.
764 Turbo 86'|Volvo 144 72|Volvo 360 86'||Volvo 360 GLS 85'|242 77"|
Website: http://www.brick-autosport.com
Facebook: http://www.facebook.com/pages/Brick-Aut ... 98?sk=wall"
mrborrie
Post by mrborrie »
unfortunately it turns out its not only the fuelpump that died..
Annoyed about it i went own with my original plan of replacing the fuelpump and changing the oil in the diff.. I'll be looking for a new block now.... :grrr:
These parts will have to wait for a new block
mrborrie
Post by mrborrie »
Donor found, block pulled. Let the rebuild begin!
mrborrie
Post by mrborrie »
Sold the parts car off and installed the engine, she runs again :cheers:
Topped off the axle with some fresh oil while i was at it, put in around a liter, it needs 1,4 so need to get some more but for now it will play
mrborrie
Post by mrborrie »
Forgot to update this in while, Had another race and did allot of things on the car.
Engine ran great even was in for the 4th place at one point but i span out.. i was pretty rusty but i had so much fun!
to bad the last race the clutch gave out so time to pull that engine again :)
Also got some damage, in the front of the field people dont play as nice as in the middle
Also working on some new stuff for in the front
mrborrie
Post by mrborrie »
Gaz damper are in, lifted the engine again to check the clutch
I confirmed after long debate that it must have been the clutchplate
Put in a NOS OEM plate and replace the Pressureplate for a used one i had around (the clutch kit is NLA both at Volvo and aftermarket?) with the engine out i put on some fresh paint
Than i repaired the damage from last race
Still having some issues with the gearbox or adjustment of the clutch..
Post by trabitom99 »
mrborrie wrote:Put in a NOS OEM plate and replace the Pressureplate for a used one i had around (the clutch kit is NLA both at Volvo and aftermarket?)
Oh dear, that's not good news ... You should be able to source an aftermarket one though.
Shouldn't this one fit? There are quite a few online shops which stock it.
http://www.daparto.de/Teilenummernsuche ... 3082204031
mrborrie
Post by mrborrie »
Actually i am now looking into the Pressureplate of a B204FT.. apparently thats the stronger brother for it? No idea on partnr's and if it will actually work though. That still leaves me with finding a propper Release bearing. at this point i would like to replace everything if it turns out this is not box related and i have to pull the engine for the 3th time this year
Is that the one?
http://www.daparto.de/Teilenummernsuche ... 3082999763
Quite a price difference, but it'd be good to know whether it works out for you in race mode :-)
mrborrie
Post by mrborrie »
trabitom99 wrote:Is that the one?
I was not aware of that model... it looks like it would fit. The model from the B204FT is IIRC Sasch 3082 204 033
http://www.auto-onderdelenexpert.nl/sachs-783892
360beast
Post by 360beast »
Great work as usual, liking the colour choice for the engine block
mrborrie
Post by mrborrie »
Did not make any photos but spend another full day replacing the clutch. The spring of the clutch arm was bent.. Car is now running and shifting fantastic. ready for Saturday.. last race of this year
mrborrie
Post by mrborrie »
had a race last weekend.
3th place race !!!!! :cool:
Ended up 5th overal in the day, Pretty happy with the result
https://www.youtube.com/watch?v=P_zHvcSJXrU
Post by Ride_on »
The 033 fits after a little trimming, you can also use astra gte F20 box clutch disk as a full 228mm disk but hard to get on its own.
viewtopic.php?f=6&t=8663
mrborrie
Post by mrborrie »
Car is for sale!
