10/02/17
first started off by seam sealing under the window edge
20170210_091939 by Benjamin Charlton, on Flickr
20170210_091950 by Benjamin Charlton, on Flickr
20170210_092002 by Benjamin Charlton, on Flickr
20170210_092032 by Benjamin Charlton, on Flickralso trimmed down the gutter rail to match the factory
20170210_092042 by Benjamin Charlton, on Flickrbut did catch the filler, so needed to touch up and also removed the bump on the passengers side windscreen where the wing meets
20170210_092155 by Benjamin Charlton, on Flickr
20170210_093151 by Benjamin Charlton, on Flickr
20170210_093157 by Benjamin Charlton, on Flickralso felt that the boot needed a little filler over the repair weld
20170210_093210 by Benjamin Charlton, on Flickras well as the drivers wing needed a bit more filler over the repair
20170210_093217 by Benjamin Charlton, on Flickrlook good sanded down
20170210_111427 by Benjamin Charlton, on Flickrwhilst the filler was drying i painted the spare set of brake disc dust shields with rust encapsulator, as mine were already rusty
20170210_111435 by Benjamin Charlton, on Flickralso painted the passenger inner wing where the welds were ground down
20170210_111442 by Benjamin Charlton, on Flickrthen moved on to painted the inside of the doors
20170210_111454 by Benjamin Charlton, on Flickr
20170210_111457 by Benjamin Charlton, on Flickr
20170210_111510 by Benjamin Charlton, on Flickr
20170210_111514 by Benjamin Charlton, on Flickr
20170210_111518 by Benjamin Charlton, on Flickr
20170210_111520 by Benjamin Charlton, on Flickr
20170210_111522 by Benjamin Charlton, on Flickr
20170210_111528 by Benjamin Charlton, on Flickr
20170210_111532 by Benjamin Charlton, on Flickr
20170210_111534 by Benjamin Charlton, on Flickr
20170210_111536 by Benjamin Charlton, on Flickr
20170210_111550 by Benjamin Charlton, on Flickrpainted up the drivers wing over the welds and the other side of the brake shields
20170210_115430 by Benjamin Charlton, on Flickrset about working on the boot lid, found a little bit of rust on the edge and so tried to remove the windows side strip.... it broke
20170210_124454 by Benjamin Charlton, on Flickr
20170210_124503 by Benjamin Charlton, on Flickralso removed the plug holes ready for the spoiler to be bolted on after painting
20170210_124507 by Benjamin Charlton, on Flickrnext set about doing some of the little task left to do
cleaned the floor hole patches
20170210_125919 by Benjamin Charlton, on Flickrmade the holes in the fuel pump cover a bit larger to accept the new bolts (i think this looks really good)
20170210_134036 by Benjamin Charlton, on Flickrdrilled out the 3 holes that the wing uses to bolt in to near the door as the metal would not hold a screw in, nutsert'ed them
20170210_140901 by Benjamin Charlton, on Flickr
20170210_140913 by Benjamin Charlton, on Flickrthen painted over it all and also all the wing clips ready for the wings to be mounted
20170210_142522 by Benjamin Charlton, on Flickr
20170210_142544 by Benjamin Charlton, on Flickrput the new painted disc plated on the struts
20170210_152339 by Benjamin Charlton, on Flickr
20170210_152343 by Benjamin Charlton, on Flickrand her first of her doors hung as well
20170210_153440 by Benjamin Charlton, on FlickrSo all in all a busy day, paint time is so much closer
More to come soon
Ben
