In spring, on every year inspection my 340 cvt failed rear brake test 3 times. Issue is that foot brake is working but weak. on 4th time passed test,but it was like okey old volvo let it be.
(They calculate rear axel mass and wheel resistance during braking or something like that.)
Front axel as it should.
Handbrake good and better than rear axel foot brake. They say rear brakes do not have enough power.
Usually I have problems with handbrake,never with foot brake.
 I have cleaned, done bleeding. open up the rear cylinders, done bleeding again.-nothing
in autumn before car went into garage, did test again still nothing. Drove about 2000 km during summer, so standing/ low usage is not involved.
1.Can this be the brake power distributor? https://www.volvo340onderdelen.nl/en/vo ... d=93033317
2. Don´t think that drums are worn, otherwise handbrake would be the issue as well.
Has somebody faced the b.p distributor issue? at least no topic in internet
 I know that on 200 series they start leaking and that´s why they will be cut out.
 I know that on 200 series they start leaking and that´s why they will be cut out.thanks and wash hands
 Kaarel
