Comparing 360 to 340!!
Hi a quick question for those in the know!! Does anyone know if there is a differance between 60 and 40 drive shafts? Are the 60 ones any thicker?
Also can anyone clarify whether or not GLT springs are different? (Leaf springs) as i believe they are but have no guarantees!!
Cheers Adam
Cheers Adam
I'm running with 360 drive shafts becouse the gaiters on my orriginals were split. They do feel a bit heavier but the od is the same. The thing I like about the 360 drive shafts is the bolts that came with them, 10mm head bolts not hex keys.
apparently glts (and gle-i) had lower, wider track, but i'm not personally convinced
Swapsea-'89 360GLT-swapped!
I take it this question was thinking ahead for a little engine swap.
The drive shafts should be ok for the power and the prop should be ok as long as you dont take off hard. I do have a plan on how to fix the problem with the prop.
