Brake upgrade Project (Disks all round) Completed!!
This is going to be a thread to keep you all updated on my brake upgrade. I will post pics that i have and keep posting until the parts are bolted onto the car!!
To let those of you know who dont already i am using 280mm Vented Golf G60 Rallye Disks on the front with Subaru Impreza calipers.
The back will have solid disks around the same diameter with 2WD cosworth Calipers.
The front setup is nearly done!! The disks are mounted on the hubs and i have refurbed some front struts to allow me to develop this setup off the car. The hubs need to be skimmed on the back then i can make the caliper mounting brackets.
Pics to follow.
Cheers Adam
Pics to follow.
Cheers Adam
Sounds exciting. Do you have to tease us with no pics yet?
2WD cossie calipers dont they use a cable setup through tha caliper and the arm on the caliper is the same/similar to the 300 arm on the drums so problem solved!!!!
Cheers Adam
Cheers Adam
Right guys here is what most have been after!!!!
The first pics are of a reconned strut!!!
Here is the complete strut looking very new!!!!
Here you can see the new platform and the extra thick bead of weld!!!
And here you can see we welded the top side aswell for extra strength!!
Right this is a comparison of the two disks on hubs!! As you can see the standard one is a dwarf compared to the G60 ones!!!
This is a close up of the new disks!!
Here you can see the extra holes drilled in the disk!!
And this is a comparison of the two calipers!! As you can see the twin pot design of the impreza ones are much larger!!
And here is a mock up of the complete setup!! As you can see its not true as there is no bracket for caliper yet!!!
What you reckon guys?
Cheers Adam
Cheers Adam
NICE!!!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
Dude! Nice one! Erm, no wanting to put a cat among the pigeons (and I havn't actually checked..) but I'm sure there was a rumour a lil while ago that Corrado G60's bolted straight on, maybe they would have not needed drilling??? Though I can't see golf and corrados being a different PCD.
Right then, so how much you selling set's for then
No mate the wheel PCD is the same but the hub doesnt use those. it use like a PCD of 96 i think not 100mm. Oh and the disks are the same disks as the Corrado ones!!!
Cheers Adam
Cheers Adam
Put me down for a set of these when you're done.
Who says i'm going into production?foggyjames wrote:Put me down for a set of these when you're done.![]()
Cheers Adam
For those of you seriously interested i can work out a price its costing me!! It ent cheap for a recon kit for the front calipers alone its £30 a side!!! I am buying bits as and when but if you are interested i will do some prices of the complete setup inc calipers!!
Cheers Adam
Cheers Adam
Well i finally got round to machining the hubs down today!!! Look looovely!!!! If you look at the pics of the hub centre you can see the fresh metal that i machined down to, i have skimmed 4.5mm off the back off these to allow clearance for the caliper carrier.
Cheers Adam
Cheers Adam
