My 340 seems to be idling really high around the 1.5k mark. How do I adjust it?
Its a 1.7 GL
Thanks
Adjusting the idling?
cheshire190e
with a long thin flat head screwdriver through the hole in the top of the air filter housing,
you should go for about 800. if you need to adjust the mixture, its a very small screw which goes into the base of the carb. you may beable to see the hole or it may still have a plastic cover on.
Matt
Matt
1987 Volvo 340 1.7
