When this happens it has always been damp weather. It had been raning all night and when I started the car at this morning it started fine. I drove to my parents house and when I tried to start the car again at there, Renix didn't give any spark. I was there only five or ten minutes so it's quite weird. I waited like 5min and knocked the renix unit a bit and checked the wires (which were all ok) and the car started fine and has worked fine now. It has done this two times before and both times it had been raining a lot and it always starts after awhile though but it's weird problem still..
And it was definately a Renix problem because it didn't even try to fire and the tacho meter needle didn't move a bit, when it normally jumps a bit if there's a bad spark or fueling problems but when it doesn't move at all, the renix doesn't do anything. It's like the power for Renix was out.
It's not a problem which occurs too often, it was two years ago when this happened last time but it's quite annoying still.
